Tap tempo on chase, does not work in Congo (with Cobalt software)
Hi
Having a problem with tapping the rate of a chase with the tap-function.
I have recorded a chase to a master, and to try to tap the tempo of it I press and hold the tap button and then tap the encoder button for the fader that contains the chase. But nothing happens. I have also tried the other button (the flash button) but nothing there either.
Also, there is a little led on the tap button that I guess should be lit when pressed (to confirm that it´s activated) but nothing happens there either.
I am running a Congo Sr with Cobalt software.
Can someone help me with this? Is there a configuration to be made in a setup-menu or something? A bug in the cobalt software. Or am I missed simply confused?
Peter
