Cobalt Seq+/Seq- FCB delay
Greetings..
I'm running Cobalt 7.1.1 on a Congo Kid.  I've noticed that when I [seq+]/[seq-], if there are parameter changes, the entire console basically locks up and stops responding until those parameters finish moving.  This can make using Seq+/Seq- to step through a cue sequence which includes attribute changes extremely maddening.  Even worse -- all other cue related functions are paused until its finished.. So if I [seq-] and then need to hit [Go] before the parameter is finished moving, the console won't respond to the go until the Seq- is fully finished.
Is this behavior configurable somewhere?  My hunch is that Cobalt is trying not to snap parameters around for fixtures that have moving parts (though ultimately, that should be up to the fixture to protect itself against).
What's going on here, and how do other folks get around it without going mad? :-)
  • I haven't ever noticed the problem. I can't recreate it offline with v7.2
    Seq + will run attributes at the default attribute time. You can change the default attribute time. [SETUP] & [ATTRIBUTE] will open the pop-up where you can change attribute times.
    Does this happen in a particular play file or all of the time?
    I am assuming that this is with a sequence on the main playback. Do you have "Build" turned on for the sequence?
    Good luck,
    John
  • John,
    I'll try changing the default attribute time and see whether the lag time changes proportionally. What other things pay attention to the default attribute time? Sequence steps use the step time for attribute time by default, right?
    This does happen on all play files. I tend to hit it during tech rehearsals mostly, where I'm stepping through cues with [Seq-]/[Seq+] and then expect to be able to enter my next command as soon as I hit [Seq+] for example. Instead, my command simply queues for 3 or 4 seconds and then executes after..
  • Automark & Move in B use the default attribute time. Execute Attributes for a Master will use default.
    I can't help wondering if the Master Playback faders might be involved. If you have the faders in the middle of a fade, it will lock-up some functions. Try using the faders to "bump" into the next preset and see what happens.
    Do you have any external fader wings attached?
    Have you tried running a face panel test? It is in the system settings shell under the Utilities tab.
    Another thing is to run a "Deep Clear" from the same tab.
    If these things don't help, call Tech Services! They are there to help, and can walk through solutions in real time with you.
    Finally, 7.2 was a really big update. I absolutely understand not messing with things when they are working, and you are in the middle of shows, but I would recommend you think about updating. Or updating after 7.3 is released.
  • Thanks for the info on what else uses the default attribute time..
    I have verified that changing the default attribute time changes the length of time the console is "locked up". So, as a tech week workaround I can just set this value to .25 or similar and be much better than previously at least, and then I can set the value back prior to an actual run through.
    Master playback faders don't seem to be involved.. no fader wings attached (Congo Kid, so doesn't support them). I've done face panel tests, but I think this is a software thing -- I have two Congo Kid's and they behave identically..
    I'll definitely plan on putting 7.2 on there after the end of this show. I'm curious to mess with cue lists -- I admit I don't understand what their purpose might be, other than to more easily move a chase sequence from show to show without worrying about preset numbers bumping into each other or something..
    I may indeed give ETC support a call -- the delay seems like a bug, or at least unexpected behavior that should be documented..
  • It sounds odd that the default attribute time would affect any of this.
    Could you give us an indication on how many devices you are using in this show and how many devices there are in a typical cue?
  • Anders,
    Not many -- I'm quite a small venue. I have 44 standard dimmers, and then generally 10 RGBW LED mover fixtures. The delay only occurs if FCB parameters on the RGBW movers change..
    If I have the channels selected when I hit [Seq+] or [Seq-], I can see the attribute values changing and that change seems to be done at the default attribute time value. If I change the default attribute time, that attribute value change fade changes duration to match, and the length of time the console is "locked up" also changes with it.
    Happy to send any show files or do any other diagnostics you would like.. I have two Congo Kid consoles and they both act identically, so I don't think it's hardware related, though..
  • Ok. So the amount of devices should not be a problem.
    Do you see an hourglass in the top right corner when the console locks up? What is puzzling me is that you can see the attributes executing on the screen even if the console appears locked up, which means it isn't really locked up.
  • Anders,
    I am not sure about the hourglass -- I will be in venue tomorrow evening and will check it out. I'll also try to take a video of the whole process and the lag/delay/lockup I experience in case that will help..
    I agree that the console isn't really locked up, it's just that it must be ignoring most command input until the [Seq+]/[Seq-] fade operation is completely finished. Since I'm using Seq+/Seq- to cut around in my cue list during tech, it's not intuitive that this should block out other console functions, and so the issue is I'll enter a command and nothing happens for several seconds, by which time I've probably started re-entering the command (and all the other issues that come with input lag)
    Thanks for chewing on it!
  • A short video would most likely be helpful. It is still a mystery why the execution of attributes would prevent console actions.
  • Anders,
    If you need a higher quality copy of this let me know.. I apologize for the length, it crept up toward 5 minutes, but I think this demonstrates the issue. Happy to do whatever testing or take more videos if it would be helpful.
    https://youtu.be/ThzIc2jIPWg
    Joe
  • Anders,
    Any thoughts after seeing the video? Should I open a support case?
    Joe
  • Hi Joe,
    Sorry for the delay on this. I watched the video last week but I didn't have any ideas about what is happening and therefore not much to say about it. We haven't been able to look closer at it yet but will do that soon. However, it isn't a known issue as far as I know and I am a bit puzzled by the behavior you see.
    Regards,
    Anders
  • Anders,
    Gotcha, thanks for the update. I have a couple week break between productions -- would it be helpful if I update from 7.1.1 to 7.2 just to confirm that the issue is still present on latest?
    Joe
  • We have now tried to reproduce this on various consoles, without success. Updating to 7.2 would be a good thing to try, although I can't see how it could change this specific behavior.
  • Anders,
    Okay, I will update to 7.2 (possibly tonight). Assuming the behavior continues (I assume it will) I will grab a copy of the show file for you, in case its an artifact of my device template or something..
1 2
