Choppy Fades
I'm having issues with choppy fades/dimming using Gadget 2 and Cobalt.  If I run in EOS everything is smooth.  The best way to describe it is let's say EOS uses 100 steps for dimming but Cobalt looks like it uses maybe 30 or 40 so it looks choppy. Not actual numbers of course but dimming definitely looks choppy in Cobalt.  Any ideas what may be causing this?
Austen
  • Version on Cobalt?
    Is in in all fades? X-fade? Masters?
    Any network running?
    Wings, midi....
  • Version 8.2.0, all fades, no network, no wings I'm running ETCnomad...
  • Can you send us a screenshot of the About > About Cobalt tabs?
    Best to email to: cobalt (at) etcconnect (dot) com
  • I haven't had a chance to grab a screenshot yet but do you think maybe the choppiness is from the profiles for the fixtures I have?  I have 2 Chauvet 4Bars (15 channel mode) and 2 Venue TriStrips (14 channel mode), both are in the library to patch but not sure if something is off compared to EOS.  I'm having the same issue with both types of fixtures.
  • Hello,
    I've got an issue like you and for it was a problem with OSX. With High sierra it working fine and when I've switched to Mojave, fades and crossfades went choppy (as you said)... Hope it's help
