Hello,i want to send go from congo kid with cobalt V8.1 to the qlab4 software, i have a router between my console and my mac. I can't seem to find the right syntax to put in a macro to trigger via OSC or UDP.Thanks for your help
Things that are linked to a sequence step (Master Links, macros etc) are always executed when the step is loaded in the Next (B) field of the crossfader. The idea is that in most cases, these are used…
i can't help you with the cobalt side, but the osc string you want to send is /cue/x/start (where x is the cue number). this is the syntax that qlab expects.
this will have to be sent to qlabs IP address, port 53000.
and on the qlab side you have to enable OSC control. in qlab setup you only have to activate OSC by ticking the option at the top, you don't have to assign any osc strings in the long list below.
If you trigger in presets, Cobalt have a bug(?) where you have to put the OSC command in the preset AFTER the one you want it triggered in. So if you have preset 1 to 5 and want it triggered in preset 3, you need to put the OSC in preset 4....
It can be it is fixed but I had big problems with this....
Things that are linked to a sequence step (Master Links, macros etc) are always executed when the step is loaded in the Next (B) field of the crossfader. The idea is that in most cases, these are used as a preparation for the next crossfade, before it is executed with the GO key.
hello, thank you for your answer, here is my configuration
because it doesn't work, and in my qlab I put 192.168.2.10 ip from my mac with port 53000 and the IP of my router is 192.168.2.1
Thank you for your help
Thank you for your help, my config is after
