TEMPLATE FOR CONGO JUNIOR
CAN YOU SEND ME IF ITS POSSIBLE, THE TEMPLATE FOR THE MAC AURA LED OF MARTIN
MY CONGO JUNIOR VERSION  IS 6.1.1.9.0.57 LIBRAIRIE 4.6.2
I MUST RECEIVE A COMPANY WITH THIS MACHINE
THANK YOU TO ANSWER QUICKLY WITH MAIL IF YOU CAN GIVE ME TO PUT IT ON THE COMPUTER WITH MY USB KEY
  • Hello,
    I'm checking on v6.3 now
    If you look in the import template wizard extended library, under martin there are two templates i can see for the Aura. It's worth looking in you're extended library .
    You could update the desk to version 6.3..... the template is in there
    Or you could update to the new 6.3 congo offline software on your computer and copy a show file with the aura template in then import it into the desk if you're in a rush.
    hope that helps
  • Hello,
    Here are templates for Mac Aura. You can use the import wizard to import it to your show.
    If you are using the Auras in standard mode, use template "Mac Aura Std"
    If you are using the Auras in Extended mode, there are two ways to patch the fixture with these templates:
    1. Patch with the template "Mac Aura Ext.". It contains all parameters in one device.
    2. Patch "Mac Aura Ext. Head" and then patch "Mac Aura Ext. Aura". The head part contains Pan/Tilt and colormix for the beam, etc. The Aura part contains the aura effects and aura LEDs that light up the lens.
    Hope this helps,
    Oskar
    template mac aura.asc
  • Hello
    I' m using congojr 6,3
    and mac aura
    i can' t find the intensity2 for the aura led  (adress 21)
    Where is this fontion
    thanks
    sorry for the english i m french
    ludo
  • As this parameter is in the "Intensity" class of functions, it won't turn up on the encoders by default. (It's not Focus/Color or Beam)
    You'll need to assign it to a User encoder bank (U1 - U3)
    - Found under the {Devices} and {Effects} softkeys.
    To set those up, either look in the Browser or hold [Modify] & press the {U1 - U3} softkey.
    I'd recommend putting Intensity2, Red2, Green2 and Blue2 all on the same page of User Encoders.
    When programming you can change the encoders to your User Encoder pages either by pressing the U1-U3 softkey, or hold down [C/Alt] and press [Focus/Color/Beam] for U1-U3.
    Alternatively you can open the Parameters list and tell Congo to classify it differently, eg as a Color type parameter.
  • thank you
    finally i choose to change in the parameters list
    and chose intensity parameter
    it s the best to use the mac aura
    the dimmer use for the both leds
    bye
    ludo
