Hello,
I am using a Congo Jr. Console and an iPad with you iRFR App version 1.2.23
The console's IP address has been set up and remote controls are enabled.  If I go to the iPad's wifi settings it says it is connected to the console.  When I go to the app under settings, I can select the jr. as my console and it claims to be connected, however when I return to the app's welcome screen the app will not connect and I get the error message "No Connection. Connection failed.  Connection refused."
I have tried several different fixes, including using different IP addresses, and restarting my equipment, but nothing has worked. We have also tried to connect to the console with two different iPhones belonging to our employees, also to no avail. The same iPod has been used to connect to the same Congo Jr. in the past; we've not had a problem before and I don't understand why it will not connect any longer.
I would appreciate any advice you can offer as the inability of the iPad to connect to the console is hampering our productivity during focus.
Thank you,
Sarah Flanagan
Assistant to the Production Manager
Louisiana Tech University
