Error message
Hi
i have an error message has the beginning of CONGO
The file or directory C:\System\VolumeInformation\_restore(8C74E3FF-5E9C-457C¬¬-8A48-1B34ED782C3C)RP36 is corruptand uneadable. Please run the chkdsk utility
i clic on OK and it run normally..
have you already seen this problem  (i hope i've well copy out)
Pierre
  • hi Pierre,
    please go into Congo Setup->Utilities->Run Checkdisk
    This should solve your problem. This is usually caused
    when the console is not properly been shut down as when
    the power is suddenly turned off to the console. This
    should not be normal operating procedure as the console
    should always be shut down from the browser or welcome
    screen.
  • Hi Corey
    I try this morning and i tell you if it's good
