Hi
I have a little problem with handling led rgb fixtures that are running in chases on the main playback and on masters.
If a cue has a chase running in it and you fade to the next cue that has no chase running the led's seem to stay in the last colours that they were in during the chase and the new information in the new cue is ignored.
Is there a way around this as when you re insert the cue the values go to the correct ones.
i would like to get to the bottom of this as it is messy to keep re inserting the preset again.
Regards
Ges
