Hi Carl -
The IPX use of WYG is separate from the ETCNet2 use of WYSIWYG. I'll explain...
You can connect Congo to WYG using ETCNet2 EDMX. If you want to do this, you will not need the IPX protocol or the console edition driver. What you won't get is any Autofocus capabilities as EDMX is a one-way protocol - Congo > WYG. You would need to patch your show in the EDMX universe in WYG.
You can connect Congo to WYG using IPX and the console edition driver set. If you want to do this you have to have the IPX protocol installed and set to a frame type of 802.3, the console edition driver installed, and the WYG show patched to the normal (not EDMX) universes) which you then need to bind to Pronto console outputs in the WYG Device Manager. Using this driver and IPX, you get the Autofocus and Autopatch connection between Congo and WYG for more interactive control.
Does this help? I know it can be confusing...
Thanks -
Sarah
Carl ... assuming you wish to utilize the autopatch feature ... per Sarah ...
You will need to create new DMX universes in WYSIWYG to bind to the AVAB Pronto.
Unfortunately I currently don't have my dongle so I can't walk you through it .. from memory I believe it's done on the "Data" tab ..
Send Dany a note at Cast ... techsupport@Cast-soft.com
He'll get you squared away ..
Hi -
IPX is not available in Windows 7. You can still use ETCNet2/EDMX, Net3/sACN or ArtNet to communicate with visualization programs running on Windows 7 machines, but you will not have the AutoFocus functions or other bidirectional options within the visulalization program.
Thanks -
Sarah
Just started playing with the offline editor on my XP laptop with wyg . I've managed to get the Congo console option to connect but but nothings lighting up.
Anyone been through this and have some crucial advice for the settings in the various places ?
Cheers
