effect
a red white effect is running on a master ok
why when i stop effect master at 0 the effect stop but not realease
like MA master at full effect running
master at 0 effect realease
another question is there a way to put all or some master at 0 with on touch
thanks
  • Hi -
    If I understand your request correctly, you want the red or white color to go back to what it was before you ran the effect, correct? At this time you will need to perform a restore of some kind to get that color back. Depending on how you got the previous color on stage in the first place, this could be pressing the REFRESH key on the main playback, replaying the preset with GOTO or using a delay in the next step to ensure that the new/background color is executed after the effect is out. We are working on a feature to make this easier in a future release.
    The way to get all masters to 0% quickly is to use the C/ALT & MASTER key shortcut. You can also select masters by clicking/taping them in the Masters tab or Masters Dock (or select them using the following syntax: # MASTER # + (or THRU or -)) then roll down the level wheel or type in a level manually. This syntax will only work when focused on the Masters tab or dock.
    Thanks much -
    Sarah
