Hi all,
1) Is it possible to import or convert a disc of memories recorded for use with a Strand 300/500 series desk to use on a Jnr?
2) Do you have a release date for v5 software in the UK.
John
Hi all,
John
Hi John,
To import a Strand showfile you need a program called Showport from Strand. You must install this in the root directory of your windows installation [c:\].
1. load the show file into Showport
2. Export it as an ASCII file ( I think it is Menu-> Export-> ASCII)
3. Load this file from USB as you would load a normal show file
It will not import Macros or chases. It will work very well if you import a conventional show. Part cues will be imported as channel times and so on. One thing you have to check are the times on your cues due to the fact that 0 or no time will be replaced with the default go time.
Hope that helps
Florian
Thanks Florian,
Thats the easy bit, now all I have to do is find someone in Strand/Gentec/Phillips.....
Best wishes
John
Try this link: http://www.strandlight.com/Software/Showport/v2.5sp.zip
Add this link to you bookmarks:
http://www.strandlight.com/US/softwares.html
It has many of the useful utilities from the old Strand - took me a lot of Google to find.
