I have just been using V5 for the first time, I found the new effects feature very simple to use but appear to be having problems when I return to the desk the next day.
I have stored 3 effects:-
Effect 1 random on front of house
Effect 2 random on stage lights
Effect 3 random on back lights
After programming and setting up these ran great, I could run them manually by selecting for example 3 effect level wheel, I had no problem inserting and running them from a preset (even managed to add more than one effect to a pre-set), then I saved the play.
When I ran the play the next day the effects did not appear correct, when I ran them manually as above the front of house ran for all 3 effects, checked them all in the editor and all the effects were as set right channel No etc (but did not run that way), the only way I could make them work again was to delete effect 2 and 3 and re-program them and all was ok, till the next day I had the same happen again?
Hope this all makes sense and thank you in advance.
Neil
