to use the fan function on CMY colormixing
Hello again,
I have one other issue where I can't find a solution myself.
Is it possible to use the fan function on CMY colormixing.
I want to use it the same way as I use the fan function on the PAN/TILT function.But it doesn't work that way.
Is there another way to get the same result.
Thanks again.
  • Hi there -
    FAN should work exactly the same way on any parameter as it does on pan & tilt. The trick is that you need the parameters to be at a level other than 0% or Full. Try placing cyan at 50 on a number of channels, then use FAN. It should work quite nicely.
    Hope this helps -
    Thanks -
    Sarah
