Group issue with effects
Hi all,
We have noticed that if you edit a group, all groups after the get bumped up by one in the effects playbacks.
The workaround is to delete the group you want to edit and then re-record it under the same number and everything will work.
This will be fixed in v5.1
Bullen
  • This explains a lot.  I had this happen in the last show I did, all my Dynamic Effects suddenly had the wrong groups in them two days before opening and I couldn't figure out what in the world happened.  I figured it was just a glitch and updated all the presets and luckily didn't edit any groups after that.  Thanks for the heads up!
    J. R. Lidgett
    Salina Community Theatre
