Recording all attributes in a cue
I program an annual panto which for the last 3 years has been on Congo, but I don't understand the tracking on this desk. What I want to be able to do is for when I press RECORD CUE, that cue stores all the information and attributes (i.e. it does not retrieve previous information when the cue gets played back).
 I have found that, even after creating a look with a load of moving lights, they always revert back to the position they were in the previous cue. I just want to be able to record them in a new position and different colour and tell the desk to remember all that information rather than drag it from a previous cue. I hope this makes sense.
 Look forward to your comments,
 Jonathan
  • Hi Johnathan,
    Go to play settings and choice which record Atts mode best suite you. But beware all atts record can get messy.
    Remember hight-light the movers and hold record then hit att to record them as well.
    Carl
  • The best mode for people who don't like tracking is Record Attribute Mode: "Active".
    This records all attributes of all channels and effect playbacks that are above 0%
    - If you want to 'mark' a channel so it moves earlier than Automark, set it to the "M" (Mark) intensity, using the Mark softkey, under Channels.
    [edited by: Richard at 1:29 AM (GMT -6) on Sun, Sep 28 2008]
  • Hi Jonathan,
     The easiest way to set what is recorded is in the advanced record window. When you hit [Record] press [Tab] to get to the advanced Record window. Go to Record attributes option where it, by default, says 'Changed'. Press [Modify] till it is set to [Active]. As Richard pointed out before, this will now record all attributes for all channels >0%. If you want to use Attribute Tracking you can still do that (new in V5)
    I hope that helps...
    Florian
