I think this is just a setting I've not found: quite often I run shows w/color palettes loaded onto the Masters so I can manually push color on the movers. Yesterday, on a show I had copied from another older one, suddenly my colors were triggered automatically when I started the fade, snapping from color to color in 0 seconds. I'm not aware of having changed any master settings, but when I imported settings from another show file the problem went away.
I compared the Master Settings and Attribute Settings of the pre-import version of the show and the post-import, and saw no differences. Where is this controlled from? I'm sure I'm just missing it somewhere, though I did dig through the manual.Under "Master Playbacks- Times" on p. 117, it says "How the time affects fading the Master manually depends on the Master Settings. See Master Time Settings," which unfortunately isn't a link.
Anne S
