Emergency help – MTC to Congo
Normal 0 21 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:Standardowy; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hello I have emergency topic with MIDI Time Code in Congo.
I used:
- Laptop
- M-AUDIO (http://www.m-audio.com/products/en_us/Uno.html)
- MIDIOX Sofware
- Connected to Congo, set in Setup “Read MIDI Time Code (MTC)”
I set some time code values and works great.
Now I am in theatre and there is a strong need to receive MTC from a Player – SONY PDW-F70 XDCAM (see attachements). There is Time code from BNC output.
Please help:
-         does somebody all over the world did such connection type and can help
-         what kind of cable I should use – pins connection
Till now I did tries with connecting:
BNC               DIN5
GND               2
Signal               4
BNC               DIN5
GND               2
Signal               5
BNC               DIN5
GND               5
Signal               4
But it does not work.
Please help.
Thanks in advance,
Adam
