[edited by: Patrick Matheson at 12:50 AM (GMT -6) on Wed, Apr 25 2007]
Currently, there are no images of the keyboard layout. Have you found the physical console button/offline button mapping table? See below for the most recent table.
Most of the console buttons have a corresponding keyboard hotkey (like P for PRESET, S for SEQ etc.).
So, essentially, the offline keyboard behaves exactly like the console (including button combinations like SEQ & PLAYBACK) once you know the console button keyboard equivalents.
Hope this helps!
Off line encoders: I assume that you mean how to control the parameter wheels in the Moving Lights dock, correct? Just drag the wheels with the mouse.
On a Macintosh, use Command instead of Ctrl.
Console Key | Keyboard Key |
- | Keypad Ctrl * |
- | Ctrl Left Arrow |
+ | Keypad * |
+ | Ctrl Right Arrow |
A | A |
ALIGN | Ctrl A |
ALL | Keypad Ctrl - |
AT LEVEL | Keypad + |
ATTRIBUTE | I |
B | B |
BEAM (B) | Alt B |
BLIND | F3 |
BROWSER | F10 |
C/ALT | Backspace |
CAPTURE | C |
CH | Keypad - |
COLOR (C) | Alt C |
COLUMN | F9 |
DELAY | Ctrl D |
DELETE | DELETE |
DEVICE | D |
DISPLAY LIST | J |
DYNAMICS | E |
ESC | ESC |
FAN | Ctrl F |
FOCUS (F) | Alt F |
FETCH/UNDO | Keypad Ctrl + |
FLASH MODE | F |
FORMAT | F4 |
GO | Ctrl G |
GO BACK | Ctrl B |
GOTO | G |
GROUP | Alt G |
HELP (?) | F1 |
HIGHLIGHT | Ctrl-H |
HOME ATTR | F5 |
IN | Ctrl I |
IND 7 | Ctrl F7 |
IND 8 | Ctrl F8 |
IND 9 | Ctrl F9 |
INSERT | INSERT |
LAST | L |
LOAD | F6 |
LIVE | F2 |
MACRO | Q |
MASK | K |
MASTER | Alt M |
Master Keys 1- 10 | 1-0 |
MODIFY | Enter |
MUTE | Y |
NEXT | N |
NOTE | Alt-N |
OUT | Ctrl O |
OUTPUT | O |
PAGE (lower) | M |
PAGE (upper) | Ctrl M |
PALETTE | Alt P |
PARK | Z |
PAUSE | Ctrl P |
PLAYBACK | X |
PRESET | P |
RECORD | R |
REFRESH (former UPDATE PB) | Ctrl Y |
RELEASE | Ctrl R |
SAVE | Ctrl S |
SELECT | Shift |
SELECT ALL | F7, Ctrl N or Ctrl L |
SEQ | S |
SEQ - | X & Down |
SEQ + | X & Up |
SETUP | F11 |
SOLO | Alt Y |
START | N/A |
TAB | TAB |
TEXT | Alt T |
THRU | Keypad / |
TIME | T |
TRACK | F12 |
U1 | N/A |
U2 | N/A |
U3 | N/A |
UPDATE | U |
UPDATE PALETTE (softkey) | N/A |
WIZARD | W |
In case you haven't already found this, to open up the Moving Light dock, hold [SETUP] and press [BROWSER]
(Or hold F11, hit F10 on a PC keyboard.)
Then select "Moving Lights" from either the Top or Bottom dropdown lists, and click on "OK"
You'll then get a Moving Light dock at the top or bottom of the screen that has click'n'draggable encoder wheels, clickable wheel keys plus a few others, encoder function displays, and a CMY colour picker.
If Offline is to be a commonly used item for you - consider buying an Xkeys keyboard
and using the overlay and drivers that Sarah has posted here
http://www.etcconnect.com/docs/docs_downloads/miscdocs/Congo_X-Keys_v421.zip
David
dlincecum:
I use a second vga monitor and run congo with wyg which works wonders, I can see exactly what my desk is doing with the second mon, this makes life much easier to to desk and stage with out swapping tabs in windows.
Carlos
