How to link up "Chase" with one of steps in Main Playback. Does it must use "MastLink"in Sequence lists?
Hi KK,
Yes you use a Masterlink.
One way of doing this is ( assuming yopu have the chase on a master), go to the sequence step in the Main Playback and press and hold [Insert] and then the master key to which you assigned the chase. This creates a masterlink with a Targetlevel 100% in the sequence. Goto the sequence step where you want to stop the chase, press and hold [Insert] and then the masterkey of your chase again. This creates a masterlink with a targetlevel 0%.
I hope I could help.
Florian
Hi Florian,
Thanks a lot,
Is it a only way to do that?
KK
As always with the Congo there are more than one way to achieve this. A different way is to open the Sequence list and insert the Masterlink in the step. This is done either by double clicking on the Masterlink box in the sequence step or by pressing [Insert]. This opens the Masterlink page for this step. There you can insert the Master and edit anything you want.
Florian
