Hi!
I'm new on avab presto consolle, and I'm not getting how to set a 0.0 time - setting a 0.1 time is ok, but if I type [0] [. ] [0] the keypad display remains clear and I cannot set the value.
Am I missing something?
as far as i know 0 seconds is not possible because of how the showfile format is designed. 0.1 is the closest you will get.
Thank you so much!
On the Cobalt, which came from Avab software, a 0 time cue is a preset meant to run at the default time of the console when the preset is executed. That is why it doesn't show a value.
On the Presto, can you set the default time to 0.0? IIf you can, then a preset with a 0 time will run the default 0.0 time. This is the workaround on Cobalt to make an absolute 0.0 timed event.
I hope this helps.
John
Thank you John, I tried, 0.0 value is not accepted even as a default time.
