Swap C & 0
I tried to use the swap C & 0 function in the system settings and got some unexpected responces.
I was trying to get the keypad to be in line with the standard 10 key pad of other ETC consoles.
I swapped the key caps after checking the box in the system settings.
Everything worked fine for inputing channels and levels, but when it came to entering text (ie. file name, preset text, etc) the keys defaulted to their original purpose and therefore the keycaps were wrong.
Is there a possibility that this will be fixed in later versions of the software.
I went ahead and switched everything back so that the other techs using the board wouldn't get confused.
Take care,
John
