i can't get the solo flash to work on my congo... the master is just added to the outgoing light, not replacing it..
[edited by: emma westerberg at 8:18 AM (GMT -6) on Mon, Sep 21 2009]
In v5.1.0 and older, to set a Master to SOLO flash mode, hold down the [FLASH MODE] key and toggle the mode using the Master Key.
In v6, this is one of the pages of settings accessible via the [FLASH MODE] key, or you can use [Setup] & [Master Key] to choose the option in the popup.
The [SOLO] key can be used to 'mute' all other playbacks completely..
Finally, Solo Flash Mode only overrides the other Masters, it doesn't override the Main Playback. This allows a 'background' look to come from Main Playback while busking over it with the Masters.
