Group - Channel selection order
Hi All,
I'm using Groups a lot in Content Effects, and was wondering if there's an easy way to re-order the Channel Order that is selected.
I can create the order when I select the channels i.e 1, 6,3,2,5,4 and  go  # REC Group.
However if I go to the Group window & highlight the channels in the group, for example using ALL, or select a single channel in the Group to change it's level, then the Order is lost. It defaults to lowest channel number to highest channel number. i.e 1,2,3,4,5,6.
The only way I have found to revert to the initial channel order is to re-record the Group from the Live screen.
Has anyone found an easier way?
