Congo as Backup
How works the Congo in a network ,is it a full Back-up or does it only nows what the Main-Console is doing after Synchronizing.
  • Congo can be backed up with another Congo console or a Congo jr console.
    Congo supports Synchronized Backup - which means the backup console will synchronize with the server console and stay synchronized with playback functions - use of the Main Playback and use of the Master Playbacks.
    You can run Congo with either user-configured backup or with automatic backup. In user configured backup, the user must send the play to the backup and save it on the backup's hard disk and start the backup synchronization manually. In automatic backup, the play file can be send by the server automatically whenever a New, Open, Save or Save As command is used. In this case, the play is automatically saved on the backup's hard disk, and the synchronization occurs automatically.
     I hope this answers your question.
    Thank you very much -
     Sarah
  • Hi
     When using the Congo Jnr as a backup, like we do in our ethernet system here, does the information in the independents - ie scroller psu power, smoke machines, hazers, movers power etc etc, also synch across, or is it best to manually configure the desk for the show we are synching?
     Cheers
    Steve
  • Hello-
     I'm very sorry for the delay in response to your question. The quick answer is "no, the independents do not sync". The longer answer is if you are using backup, any channels you want to have backed up in case the main server fails should be within the normal playback space of the console - main playback or masters.
    We will add this feature (syncronization of the Independents) to our wish list, however. Thanks for the question!
    Sarah
  • Hallo,
    Ich habe ein Problem mit den Client.Ich kann von Congo ( Server) keine Vorstellungen senden zu meinen Laptop (Backup). Vom Backup kann ich auch keíne Vorstellungen holen . Backup Syn funktioniert, also wenn ich GO (Server)drücke, fährt das Backup gleichzeitig mit, obwohl keine Stimmungen geladen sind.
    Außerdem , wenn ich den Client starten möchte auf den Rechner, kommt 1 mal der Wilkommesbildschirm ( Client, Offline, Systemeinstellungen), wähle ich Client an, erscheint ,,Verbinde", aber nichts passiert. Schließe ich das Programm und starte neu, bootet das Programm direkt zur Congo Software durch. Wird dann auch als Client, Backup angezeigt.
    Mein Hauptproblem ist, wie kann ich die Vorstellungen senden / holen , obwohl angezeigt wird, Vorstellung wird auf anderes Gerät gesendet / geholt?
    Mit freundlichen Grüßen
    Thorsten
  • Servus Thorsten,
    als Laptop kannst du nur als Client/Offline arbeiten. Als Client kannst du dann nur als Fernbedienung arbeiten und nicht als eigenständig Konsole.
    Mit ein Laptop kann man nicht in Backup Modus fahren.
    Backup Modus kann nur echte Konsolen (Congo oder Congo Jr oder Congo LightServer). Backup Modus heisst,
    dass ein 2. Konsole fährt gleichzeitig mit der 1. Konsole die ganze Vorstellung mit, und für den Fall alle Fälle,
    auch eigenständig des System kontrollieren kann. Ein Laptop mit Client Dongle, kann kein System allein
    fahren.
    Ein Laptop mit dem entsprechende Dongle kann nur Client oder Offline sein, und als Client, kannst
    du nur mitwerken in den System durch den Console aber nicht eigenständig - und daher gibts auch kein
    Backup (Vorstellungen senden, holen und Sync).
    Hoffentlich hilfte das.
    schöne Abend noch,
    - corey
  • Hey Corey ,
    danke für die schnelle Antwort. Trotzdem ist mir eine Sache nicht ganz klar.
    Meine Frage ist, kann ich den Laptop mit Dongle z.B. bei der Regie hinstellen, damit die direkt sehen können, welche Cue´s ich gerade speicher , b.z.w. in welche Stimmung ich gerade bin. Ebenso die Live Werte, in Echtzeit? Das was ich mache und auf meinen Monitor angezeigt wird , kann sich auch direkt der Lichtgestallter im Saal ansehen. Ist das Möglich?
    Gruß
    Thorsten
  • Servus Thorsten,
    Wenn du in Client Modus am Laptop fährst, siehst du der gleiche Live Anzeige wie auf Konsole gerade lauft. Oben
    auf dein Laptop soll stehen "Congo, Client Full Access" , dann wenn du über ein Netzwerk (switch) mit den Congo Console verbunden bist
    mit der richtiger IPs, dann ist alles gut.
    Damit - ja du kannst unten auf Regie mit Laptop sitzten, und anschauen LIVE was geändert und gespeichert wird.
    Höffe das hilft.
