Mediaservers. Controll of scrollerfan
Hello!
I have the Congo Jr consol
1. I wonder how i can get the right information and thumnails when I´m using more than one mediaserver. I´m onely getting from one of them so when I want to work with another one the files (for exampel) is incorrect.
2. How can I program, manually, a fan-valu in the sequence when I´ve choosen not to let fan follow intesity but have defined a scrollerroll (with or without colervalu)?
Best regards
Joakim
  • Hi Joakim,
    It depents on which mediaserver you're working.
    When you want to use the Arkaos dmx , there exist a version on ETCnet2. There you can see the tumbnales at your screen, working with the channel lay-out.
    Mediamaster still working only on artnet on congo, there isn't a solution yet ( our not that I know)
    Greets,
  • Hi Joakim,
    1. The media names from a connected media server are stored as range names in the corresponding template to be able to be shown on the Library and File parameters. This means that if you want to have different content in different media servers, you have to make a separate template for each of them (you can copy the existing template and give it a new name).
    2. Not sure if I understand your question correctly. There should be a Fan parameter in this case that is recorded just like any other parameter of the device. You should be able to see and edit it in the attribute editor.
