Hi-
I'm having problems with getting the Congo to talk to Par 64 Strobe Cannons the way I want it to. The fixture has a feature that if you leave the intensity at zero, you can bump the rate channel to a certain level and it will give you a particular effect. However, with the Congo not doing zero counts and instead doing 0.1 counts, it does not recognize it as a bump and will not trigger. In the same way, a cue will not fire a single flash consistently because the board does not bump the intensity to full fast enough. When selecting the levels it works fine, just not when running cues. Is there any way to work around this? Or any way that we'll get a real zero count anytime soon?
Thanks.
Mark
