Hello from vienna,
Inverting Parameters in the Device settings works not with the align function. Because if I use the align function in the focus mode with a selection of 10 ML (for example 5ML have inverted PAN), the output seems to take reference just from the template. And the align function is inverting the output.When I align 70% from a non inverted ML, then the inverted ML has 30%. So the align function is ignoring the Device settings.
That seems strange, is this what it should be.....???
At the moment I inverted the parameter PAN in a copied template and so it is working fine with the align function. But I would like to do this in the Device settings and use the align function......
thanks for answers,
Roman
