I currently have a show that uses three masters set to inhibit mode in order to do a manual 'flash off' effect.
There are two problems:
1. When the master page is changed through a page with an inhibit master, it grabs the fader and won't let go until the fader gets to 100%. Then the new assignment gets control and, if it's not inhibit mode it comes on at 100%. I can't see any ways round this other than to only use inhibit mode in those positions or never change page during a show.
2. When the desk is restarted, the channels on an inhibit master don't work properly - the only way the channel can come on is by assigning it to an exclusive mode fader (which presumably overrides an inhibit). Setting the masters back to normal mode and restarting restores normal operation.
One clue: In the master view, the page with the inhibits on appears twice. Fading up the second copy from there with the level wheel did not cure the problem.
Are these problems known about?
Is there a way to make inhibit masters inverted so that full up is fully inhibited? To me that is the way an inhibit master should work. And would solve problem 1.
Is there a better way to flash a light off (i.e. temporarily turn a channel off using a flash button or similar)?
Is there a solution to problem 2?
Using v6.0.4 on Congo Jr + Master wing on USB
Regards Trevor
