Multiple sequence with action macros
Hello
Is it possible to start a second sequence from the action macro in the sequence from the main playback?
We are using masterlinks at the moment, which is running specefic presets. This is working but this is really not what we wanted from the beginning.
Thanks / F.
  • Hi,
    Before jumping into specific solutions, could you give as example on what you wanted to achieve from the beginning?
  • Hello
    We Wanted to start/control "sequence 2" containing a few presets from the main playback (sequence 1) .
    And we Wanted to do this with à action  macro if it is possible.
    /F
  • Hi,
    This should be possible to do with Action Macros.
    Load Sequence 2 to a master.
    Use Action Macro commands like this to control it: GO M1,100,10.
    This would fade the sequence in master 1 into preset 100 in 10 seconds. If you don't specify a time, it will use the programmed crossfade times. If you don't specify a preset, the sequence will make a GO to the next cue.
    Does this solve your problem?
    Anders
