connect congo to datagate mk2 entecc by artnet
I can not connect the console to Datagate
it drives me crazy, can someone help me?
desk ip: 10.101.81.101 / gateway 255.255.0.0 and 255.255.255.255 (I tried the 2 options)
Artnet: 255255255255/10255255255/2255255255
I tried the three possibilities.
on the Datagate:
IP: 10.101.50.101 / gateway: 255.255.255.255
When do I start the console, it shows me the ip though the console and artnet (top right) but nothing comes out.
Of course, I will restart each time the console that I have changed a setting.
Thank you in advance,
Xavier
  • What IP settings do you have for each?
    There are three IP settings for the Congo Console and the "Datagate":
    • IP Address
    • Subnet Mask
    • Gateway IP
    A subnet mask of 255.255.255.255 will never work, you usually want "255.255.0.0"
    Then in the Congo Art Net settings you want either "255.255.255.255" or "10.255.255.255" as the Artnet Address.
    - The first number is either 255 or should match the first number in the IP address of the Datagate.
    Congo sends broadcast Art Net 1 for maximum compatibility.
    Secondly, Art Net universes count from 0-0, Congo Universes count from 1. Confirm that you're actually sending the universe you want.
    - By default, to patch to Art Net universe 0-0 you must patch to Congo Universe 1.
    Unfortunately I can't really help you much with the Datagate end, I've never used one of those.
  • thank you for your prompt reply,
    If I understand correctly, the IP address of Datagate must begin with the same address as the address of artnet (10.XXX or 255.XXX)
    currently on the console :
    Console IP: 10.101.81.101
    subnet mask: 255.255.0.0
    Gateway: 10.101.81.101
    Should i put the ip in automatic? or dhcp?
    on the Datagate:
    IP: 10.101.50.101
    artnet adress: 255.255.255.255
    I should try to 10,255,255,255?
    What is hard is that you restart each time the console, and there is nothing to know if the problem comes from the console or Datagate
  • Xavier, in the configuration you described, you would most likely want the Artnet broadcast address to be 10.255.255.255.
    Assuming the datagate also does Artnet version 2 that should work for you.
