Hi I have been working with Augment3d for a little bit and just did the Hamilton project. In the project they have moving 3d models that move on cue firings how does this work and how can i replicated it?
In Patch- Fixture Type: Scenic Element Movable
Patch the SEM to a channel, then in Augment3d edit mode drag a scenic object onto the SEM channel so it appears like a folder with contents.
Exit edit mode and turn the channel on/off to make than object appear. Alter that Channels XYZ values in ML controls to move the object.
Thanks so much
