I'm wading through early videos etc and have some fixtures in A3D. But I want to cheat the learning process a bit with a quick question:
I have a ML on and pointing straight down. I want to move it onto the actor. Normally I would use P&T. But, in a blur of new stuff I thought I saw a way to select where that beam hit the stage and allow me to pull it onto the actor. Better still If I had several fixtures aimed on the actor and she moved I would like to be able to pull them all at once to the new position rather than adjust each ones P&T separately. Possible?
