Solawash 2000 dose not display correctly in Augment3d? The beam dose not display in tilt from about -18 to18 degrees.
Could you share a screenshot of this not working for you? It seems to work okay for me from a new showfile:
You may want to double-check your Quality settings in Options > Quality as they affect how the beam-end of light will appear on different objects:
Here in Low - Pass-through you notice there is no circle of light on the floor any longer. That is expected.
Ok, medium & pass-through does give results.
Thank you
