Is there a specific plugin for VW2021 coming? The 2020 one does not seem to be loading for me.
-Ed
-Ed
^^^ Same question.
We are actively working on Augment3d plugins for Vectorworks 2021. We can't specify a beta/release timeline yet for them.
Thanks. I'll go back to VW2020 in the meantime.
Hi Matt Pumplin or Seth Starr Is there an update on a 2021 plugin?
Hey there, any updates on this?
Just downloaded VW2021 with the sole purpose of using it for Augment3d, only to realize it's not compatible with the current plug-ins haha, sad day!
I've tried downgrading to 2020 version, but not sure if I can do that if I never had it in the first place.
Hi folks, we are wrapping up support for 2021 and should have something in the near future.
Thank you for the follow up Seth, very much looking forward to it.
The plugin was released today: https://www.etcconnect.com/WorkArea/DownloadAsset.aspx?id=10737503665
Just downloaded and installed Vectorworks 2020. Downloaded the ETCAugment3d Pllugin. Followed instructions in the pdf file. Vectorwroks responds with "The following plug-ins are not compatible with the current version of Vectorworks and were not loaded." I have tried this with both the Zip and Unziped files. Same response - not compatible! Any thoughts ???
Pardon the spelling errors!!! And make that Vectorworks 20/21.
Please post a screen shot of the .zip file you are selecting to install.
You will need to extract the larger bundle so that you have those two zip files and one pdf file in a folder. Then select the file you have highlighted.
Frustrated! Did as you indicated. Entered the exact filename in the filename box. Clicked "Open".. Clicked "Relaunch Vectorworks. Saved the current file. When Vctorworks reopened I receive the same message!
I am not ale to post a screen shot in this dialogue box. Will try to send in another reply.
Hi Ron,
Sorry you are having issues. I just went through all the steps and grabbed screen shots along the way in the hopes it might shed some light on a variation in our processes. Of course as I write this, I realize there is a SP2 out . So in the morning I will get it installed and give it another go.
