Perhaps another obvious question but is it possible to play the cues I've recorded and watch them in Augment? And if so how do I do that?
when you playback a cue, e.g. by pressing Go, you will also see it in Augment3d. If you want to check the cue in Augment3d without having it on stage as well, you can go to Blind and select the respective cue, it will automatically be displayed in Augment3d.
Okay, even dumber question, where's the go button on a laptop? I can't seem to make the cues go!
Spacebar (must be enabled and cue list loaded on main playback)
