Transferring show to Augment 3D
Hi All
I have a show which will be doing a re-mount in a new venue so the show is already programmed and has many preset references. During programming I intentionally saved as A3d file so as to be able to update things before getting to the new venue.
When importing the plan which corresponds to the show file and after updating the fixture library all the movers seem to be pointing to the air instead of the stage. No matter how I rotate the fixtures I still cant get them to hit the stage and more importantly the focus points in the show. Is there something I am doing wrong or is there a simple solution for this?
Obviously I am unable to see the results live however I know where the lights should be pointing/moving. I am assuming this should match somewhat to what happens live.
