Robe CycFX8 basic model change
Hi guys,
I know there isn't a 3D model for the Robe CycFX 8 yet, but it would be great if there was a way to at least tell Augment3d that it was a batten fixture rather than a circular moving head. I'm using Colorado 72X battens too and it recognises that these are a linear fixture even though they don't have a 3D model either. I'm guess that because the CycFX bars have tilt it assumes they are a full moving head until the model tells it otherwise.
Looking through the 3D model list I can't see any other linear fixtures on the list (GLP X Bars would be the obvious one) so is there a current limitation that these can't be rendered?
Edit: Patched a GLP xBar20 to test and that has a correct linear MC representation (even though under 'Physical Data' it has no model assigned.
Cheers,
David
Eos 3.0.1
