Augment3d fixture export appears to be using fixtureid instead of inst type
I am using VW 2021 and exporting augment3d fixture data. I have many D40s on the plot with different symbols for each lens type. When running the import in Eos all of the D40s appear as ETC Selador Lustr 72. On closer inspection of my symbols (these are the default vectorworks library symbols), I found that there is a field in the Light Info Record called FixtureID. All the D40 symbols share the same FixtureID and that is apparently the field used by the import.
Is this the intended behavior and the symbols in VW need to be updated?
Parents Reply Children
No Data
