I've created a pixel map which is a simple grid of 30 x 8 dimmers. In real life these will be sunstrips.
I've got content playing across the pixel map which shows up in the preview, but I am not seeing output in the model I've created in Augment3d. The channels are patched as dimmers and correlate to the channels as laid out in the pixel map. The pixel map is set to output on sACN and DMX. The server channel and layer channel are at full.
I've confirmed the Augment3d channels are set up correctly as I can control each channel manually. I just don't see any output when pixel mapping.
What am I doing wrong?
