See the video below. I change the beam angle to map to field angle and then go to either the Options window or the fixture linking window...when I back out of that, the beam angle mapping I just set has been reverted. I had to redo an entire plot import because of this when none of my field angles came in because that mapping didn't 'hold' the relationship I had set.
