unwanted dimmer in type field
I am trying to delete "dimmer" in "type" field  in channel does not have a dimmer assigned to it on an Ion.
  • It doesn't do anything bad, so you can just leave it if you want. but if there are OCD reasons (believe me, i understand ;) ) you should be able to use the Unpatch softkey when you're in the Patch tab:
    Chan 1 {Unpatch} [Enter]
