When I start editing effects nomad turns in to blind which switches my augment3d view to blind as well. Therefore I cannot see how changes in parameters affect my rig immediately. Is there an option to change that?
Hi claes,
This is not currently possible, but visualizing effect edits in Augment3d is on the list for future development.
Thanks for the quick answer. That's great to know. I became a big fan already using Augemen3D. Thumbs up! Another issue could be implementing scenes for different stage designs in one show.
that's possible through Scenic Element and Scenic Element Movable channels. you can connect your set to those channels and then either make the set invisible or move it through cues.
wow, okay, scenic movable channels makes it even possible to simulate turntable stages. great help!
hello, any news about this improvement?
No. This is still logged as
[EOS-50900]
Augment3d should show running effects and their changes while in Effect Blind
bump. are there any updates on this topic? its quite annoying to toggle between Blind Effect and Live when working with effects in Offline for example. Especially because Blind Effect just freezes the A3d output (while Blind shows you the Blind Cue). This surely has a technical reason but it doesn't feel right to me.
There currently is not. I will add a note that you're running into this as well.
Another bump. I am currently learning eos and this seems like a big limitation to augment3d. One of the main things I am using augment3d for is as a visualiser for learning when not in the venue, and building my effects library seems like one of the major things that will take time to get right. Even if it was a manual option to put augment3d into a mode where it just renders the live console output no matter what else is happening.
