FPE tab not showing up on Ion. Is it not supported on the ion? I have updated to the latest software and my ion is compatible with 3.x. it would be really nice for me to use this as come fixtures don't go where they should in Augmented.
Hi Tony FUHSD ,
FPE is supported on Ion consoles (and any console or computer running 3.x software). Remember that it is a sub-tab in the patch screen:
FPE stands for Fixture Position Estimation and is designed to assist with you getting the fixture positions into Augment3d by calculating where they are based on their pan/tilt values when pointed at certain positions. Check out Setting Up FPE for more information on getting that started.
If the fixture positions are correct in Augment3d but the fixtures aren't doing what you expect, check out Fixture Physically Pans or Tilts in the Opposite Direction from Visualized Movement - Electronic Theatre Controls Inc
Figured it out. turns out the tab wasn't showing up when the monitor was in portrait mode.
Thanks for finding this. I will write it up as a bug. Do you happen to know the size of your Portrait monitor? A typical size for 21" monitors is 1920 x 1080.
Its a 19" 1280x1024 monitor. it's passing through a DVI to VGA adapter right now.
