Does the vectorworks augment3d plugin work on Vectorworks 2022? I don't want to upgrade if it doesn't, as that's a pretty important part of my workflow now.
is there a Vectorworks 2022 plugin coming? I have tried 2020 and 2021 with no luck.
[Moderator Note: Separate Thread Joined]
Hi Mikey Slater ,
Can you clarify your statement :
Does this mean you have tried the current Augment3d plug-in V1.1.1 with Vectorworks 2022 and it does not work for you?
Or are you having issues with VW 2020/2021 and looking to see if we have something updated to 2022?
I don't have a 1.1.1 for Mac, the download from the home page only has 1.1.1.21 for windows and 1.1.0.13 for Mac.
I tried both of those and neither work. it gives me the error,
A script error has occurred. Refer to the "Error Output" for a further Explanation.
Traceback (most recent call last) :
File "<string>", line 129, in <module>
File "<string>", line 105, in InstallMac
FileNotFoundError: [Errno 2] No such file or directory.
Mike
Sadly you can't mix-and-match versions.
All 'native' Vectorworks plugins are only compatible with the specific version they were compiled for.
The final version of the 2022 SDK was only released last week, we are working on integrating this.
Thank you. As Richard pointed out below, we don't yet have a 2022 compatible version of the plug-in but it is something we're working on.
Just checking to see if we are any closer? Was hoping 3.1 might include support for VW 2022!
The Augmented plug in will not work in Vectorworks 2022. I installed it as instructed. but after restarting vectorworks, it is not showing up. I tried 3 times with no luck.
[Moderator Note: Moved from incorrect forum and joined to existing thread]
