EOS Nomad
I7
16g b ram
M2 256
GEforce 1050
With the change of type fixture A3D crash with this fixture 16 and 20 ch, all the other fixtures tested (even non 3d ones) do not create any problems for EOS
Giovanni.
EOS Nomad
I7
16g b ram
M2 256
GEforce 1050
Giovanni.
...crash also on new show file starting zero test on two different pc with win 10.
Sorry you've had problems. I've tried reproducing in 3.2.4 and nothing bad happened. I'm assuming this problem is fixed unless you tell me otherwise.
Thank you.
HI, the problems has been solved in version 3.2.from 3.1 to 3.2 the problems was present, ETC Italy it checked this problem on all console, gio, ion xe and eos. Now work.
thank you
