Hello all,
Just a quick question.... when can we expect an updated VW plug in for VW2023?
Kind regards,
Florian
Hello all,
Kind regards,
Florian
Hi Florian!
We are working with Vectorworks to take advantage of their MVR export. This will require VW2023, as well as Eos v3.2. We are hoping to get v3.2 to closed beta in the next few weeks, and release at the end of December. We'll make announcements about it in the beta forums, so keep an eye out and sign up if you're interested.
~n~
Thank you for this update. Looking forward to testing it.
Hi I am new here and had a question. Is there a possible release date for the plugin for Vectorworks 2023? Or a work around? I have a show coming up and it would be great to be able to have the show lights and cues set prior to the show.
Hi Gary, if you would be willing to send over your VW2023 file and/or MVR export? If so please please drop your file in this Upload Link. This would only be used by ETC for developmental purposes and would not be shared outside the Eos/Augment3d Development Team.
Hi Nick, Any update on if there is a beta of this yet or an expected release date?
I just upgraded myself and my lighting class to Vectorworks 2023 and now can not use augment 3d. Is there a plugin for VW 2023 yet?
Howdy! As mentioned above, with VW2023, we are not developing a plug-in, but instead are using MVR export. For this, you will need VW2023 SP2, and Eos v3.2. Eos v3.2 is going into open beta next week, so keep an eye on these forums to sign up and download the software.
We're going into open beta next week, and we are looking to release Q1 next year.
I used to be in the Beta group for Eos 2.9, but it looks like that didn't carry over into v3. How can I join the party?
can you get to this link?
community.etcconnect.com/.../
There should be a clickable orange banner across the site telling you to join.
That worked. Thanks!
Hello!
Just tried to install on Vectorworks 2023 SP3 R1 (Build 686131) (64-bit) the Augment3d plugin for Windows but the software advise me about the following script errors:
Any suggestion?
Tank you!
Francesco
Hello Francesco! The Vectorworks Plugin is not supported for 2023. I would suggest stepping back to 2022 or looking at the Eos v3.2.0 Beta for the alternative solution.
TJ Hill thank you for your quick reply! Waiting for Eos 3.2 stable release to test it. Could you confirm me is available also for VW2023 SP3?
Yes SP3 is what Beta calls for MVR import
