Hello, I have to integrate Showtec sunstrips in my patch and in my augment3D, but they are not defined in 3D, is there a solution to import a model, or to create it and have a slightly more realistic rendering ?
Thanks in advance
Thanks in advance
you can't import your own 3D models for fixtures. but you can assign one of the currently existing models to your fixture profile. in patch, click Fixtures to go to the fixture editor, select your fixture profile and then use the softkey Physical Data. this will open a new menu where you can choose the fixture model from a list of currently available ones. for a sunstrip you could try Generic > Bar.
Thank you for your answer, but in generic I don't have bar..
Are you looking here?
what's your software version?
i'm in 3.1.5 and i can see them. don't know with which version exactly they were added
I am a little bit confused.
EOS v3.1.0 is running Lib v3.1.5 ?
These generics were added in Eos version 3.1.2.
nino I would recommend that you update to version 3.1.5 of Eos software and then, if necessary, reapply the 3.1.5 fixture library update. You may see strange behaviour with 3.1.5 fixture library installed on 3.1.0.
thanks a lot ;) it's works !
