I have a png image file of a cut cloth i have imported to Augment3d, however, the "see-through" part of the image is just displayed as black, is this a fault or does augment3d not support this?
Is this use case for materials on model objects? Can you send me the PNG?
Did you get this done? If not, please let us know.
Thank you.
Hi, unfortunately im still unable to do this
Is your use case for materials on model objects? Did you happen to send us the PNG? If not would you mind sending us an e-mail? eos(dot)moderator(at)etcconnect(dot)com
