I used a S4 Dimmer luminaires and than I tried to insert a frost in Patch > Database > Gel > R119 but I don't see any change in Augment3d. Of course i could change the Edge, but are there other solutions?
Thanks for your help.
I think Frost or Clear gels are not part of the color database.
You will not find them in the color picker.
This is correct. At this time the work around is to adjust Edge if you need to adjust the quality of light in this way.
In fact, I thought you could do that because you can put it into the database.
but obviusly you can't find it in the color picker, so I undertsand what you mean.
