Hi, so I am attempting to recreate the SIX lighting rig in AD3, and I see that there are custom gobos for the show. If I downloaded the gobos, would I be able to import them into the fixtures? If so how would I do that?
Thanks!!
Max
Thanks!!
Max
Yes you can!
Go to Patch and select the channel, go the Attribute section and have a look on the right hand side of your CIA. You will see a field called Gobo_Select. Click it to open the wheel editor. Copy the existing wheel and then modify it.
You can find the procedure in this chapter of the manual: https://www.etcconnect.com/WebDocs/Controls/EosFamilyOnlineHelp/en-us/Default.htm#05_Patch/03_Using_the_Scroller_and_Wheel_Picker_and_Editor/Editing_Scroll_Wheel_Copy.htm
How would I add the picture of the gobo to the wheel?
You first import the gobo image into the showfile by opening the CIA and selecting the Gobo option in File > Import.
The gobo import would best be done in 3.2.7 as the resolution for imported gobos was increased to 256x256 pixels. The resolution of 64x64 in previous software versions didn't render particularly well in Augment3d.
When editing the gobo wheel (as described in the manual, cf. my previous post) you'll find your imported gobo in the gobo library under the Custom manufacturer.
Can you please simplify this? I have the gobo downloaded but I am unsure how to import it to Augment3d
You don't import it into Augment3d, you import it into Eos.
Which part of the manual section posted above are you struggling with? What's the make and model of your fixture?
I am trying to import a custom gobo into THPP. I am unsure where to import it to and which fixture to assign the gobo to.
I am hoping to add a ring gobo "Aperture 2" to a solaframe 3000. I am really hoping this will work.
With the channel selected in Patch, go to Patch > Attribues. Select Gobo_Select or Gobo_Select_2 on the right. Those are your two gobo wheels. Copy the gobo wheel so you can edit. For further instructions follow the instructions of the link my first reply.
